Product
Targus Classic+ 17"-18" Clamshell case - Black/Red
Quicklinx: BC46WS00 Mfr#: CN418EU
The new Classic+ laptop case is designed protect 18” widescreen laptops. The new inner sleeve with security strap safeguards the surface and gives additional overall protection to your laptop. The re-enforced handle is wrapped in a soft neoprene to provide comfort and strength. An easy to use functional front zipped organizer will neatly store your mobile phones, pens, business cards, and cables / earphones etc. The case comes with an adjustable comfortable strap when carrying the case on your shoulder.
Targus Classic+ 17 - 18" / 43.2 - 45.7cm Clamshell Case notebook carrying case
Notebook carrying case
Product Material
Polyester
49.21 cm x 8.89 cm x 34.29 cm
0.8 kg
Notebook Compatibility
18"
Product Material
Polyester
49.21 cm
8.89 cm
34.29 cm
0.8 kg
18"
Notebook Compatibility Dimensions
46 cm x 4.4 cm x 30 cm
Limited warranty - lifetime
