Targus Classic+ 10-12.1" Clamshell Case - Black/Red
Quicklinx: B3VQWS00 Mfr#: CN412EU
The new Classic+ laptop case is designed protect 12.1” widescreen laptops. The new inner sleeve with security strap safeguards the surface and gives additional overall protection to your laptop. The re-enforced handle is wrapped in a soft neoprene to provide comfort and strength. An easy to use functional front zipped organizer will neatly store your mobile phones, pens, business cards, and cables / earphones etc. The case comes with an adjustable comfortable strap when carrying the case on your shoulder.
Targus Classic+ 10 - 12.1" / 25.4 - 30.7cm Clamshell Case - notebook carrying case
Notebook carrying case
Product Material
Polyester
34.29 cm x 8.26 cm x 27.31 cm
0.57 kg
Notebook Compatibility
12.1"
Zippered, touch fastener, adjustable shoulder strap, external zip pocket
Carrying Strap
Shoulder carrying strap, soft padded handle
Europe
Product Material
Polyester
34.29 cm
8.26 cm
27.31 cm
0.57 kg
12.1"
Notebook Compatibility Dimensions
29 cm x 3.5 cm x 24 cm
Additional Compartments
Mobile phone, headphones, cable, pens, business cards, organizer, tablet
Carrying Strap
Europe
Limited warranty: - lifetime
