The Targus A7 Sleeve is designed specifically to protect the media tablet from scratches and dust. The heavily padded interior features the Tri-cell Cushion System™ which combines additional foam padding with mesh material for ventilation. The exterior features neoprene material with an industry-grade tarpaulin gusset around the edge which is highly durable and water-resistant. If used inside another laptop case, the A7 sleeve provides an additional layer of protection from scuffs and wet weather. The slipcase can also be used alone when transporting the media tablet between classes or meetings. Tri-Cell Cushion System™ 1. Quilted, air ventilating fabric 2. Shock-absorbing foam 3. Soft and durable neoprene.
- Targus A7 7 inch / 17.8cm Sleeve for Tablets - protective sleeve for tablet
- Product Type
- Protective sleeve for tablet
- Screen Size Compatibility
- 7"
- 22 cm x 3 cm x 15.5 cm
- 140 g
- Material
- Neoprene, tarpaulin
- Black
- Limited lifetime warranty
- 22 cm
- 3 cm
- 15.5 cm
- 140 g
- Material
- Black
Carrying Case
- Protective sleeve
- Recommended Use
- For tablet
- 7"
- Protection
- Waterproof, dust-resistant
- Closure Type
- Zipper
- Inner Dimensions
- 19 cm x 1.2 cm x 12.1 cm
- Foam padding, Tri-Cell Cushion System
- Lifetime
