Targus 7-Port USB Desktop Hub - Black
Quicklinx: BBSYWS00 Mfr#: ACH115EU
Get the maximum performance from your USB peripheral devices via this USB 2.0 desktop hub, offering support for up to 7 USB devices in a compact flexible unit. This hub features seven 2.0 ports, packaged in an attractive enclosure. It is ideal for your desktop set-up, allowing for easy connection and data transfer of up to 480Mbps for seven USB devices connected to your USB enabled computer. Over current protection and plug and play functionality ensure this hub will not let you down. This hub is compatible with both PC and Mac.
  • Functionality
    Instantly connect up to 7 USB devices such as your mouse, flash drive, iPod/MP3 player and more.
  • Protection
    Provides protection against short-circuits and electrical current overload.
  • Plug and Play
    No hassle setup; simply plug into your computer's USB port.
  • Power
    AC adapter provides additional power when required.
Targus 7-Port USB Desktop Hub - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x USB 2.0
USB powered
USB 2.0
7.6 cm x 6.9 cm x 3.1 cm
82 g
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
7 x USB 2.0
USB powered
USB 2.0
7 x USB 2.0 Type A , 1 x USB 2.0 Type A
External power adapter
7.6 cm
6.9 cm
3.1 cm
82 g
BBSY C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
