USB-C is the next generation of charging connector for devices ranging from laptops, phones and tablets through to wearables. This high power car charger is designed to offer universal charging for USB-C devices up to and including powerful 45W laptops. Supporting 5V, 9V, 12V, 15V & 20V charging, this is your go-to car charger for your USB-C devices. Ideal for keeping you productive on the move the 1.2m cable gives you flexibility when in use while built in surge protection protects your device from electrical spikes.
- Targus Car Charger car power adapter - 24 pin USB-C - 45 Watt
- Product Type
- Car power adapter
- 16 cm x 12 cm x 4 cm
- 170 g
- Black
- Localisation
- Europe
- Output Connector Type
- 24 pin USB-C - on cable: USB-C
- Voltage Provided
- 5 / 9 / 12 / 15 / 20 V
- Power Provided
- 45 Watt
- Cables
- USB-C cable - 1.2 m
- 2-year warranty
- Product Type
- Car power adapter
- Designed For
- Tablet, mobile phone, notebook
- 16 cm
- 12 cm
- 4 cm
- 170 g
- Enclosure Colour
- Black
- Localisation
- Europe
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Voltage Provided
- Output connectors
- 24 pin USB-C
- Power Provided
- 45 Watt
- Detachable Cable Connector Type
- USB-C
- LED indicator, surge protection
- Cables Included
- Limited warranty - 2 years
