Targus 4-Port USB Hub - Black
Quicklinx: BBSWWS00 Mfr#: ACH114EU
Type: USB Hub
Ports: 4
More than 50 in stock
£6.75 ex VAT
£8.10 inc VAT
The Targus USB 2.0 4-Port hub allows connection of up to 4 USB Devices whilst on the move. Plug and Play functionality ensures this hub is simple and easy to use whilst the device draws power from the notebook ensuring a bulky AC adapter is not required on your travels. High speed USB 2.0 connectivity ensures fast and reliable data transfer of up to 480Mbps to a variety of devices such as mice, flash drives, and MP3 players, keyboards, USB adapters and Digital Cameras. The attached USB cable prevents loss or damage to the cable while conveniently clipping to the base of the hub for easy transportation. This lightweight travel hub is ideal for use at home or on the road and is compatible with both PC and Mac.
Targus - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
Performance
Data transfer rate: 480 Mbps
USB 2.0
8.5 cm x 3 cm x 1 cm
30 g
Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Apple macOS 10.12.4 - 10.13.6
Europe
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
Performance
USB 2.0
4 x USB 2.0 Type A
1 x USB cable
Plug and Play
Europe
8.5 cm
3 cm
1 cm
30 g
BBSW C2G 2m USB 2.0 A/B Cable - Black In Stock £3.64
BBSW C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.39
BBSW C2G USB Superbooster Extender Kit In Stock £34.75
Type: USB Hub
Ports: 4
Brand: Targus
Price Range Ex VAT: 0 - 50
