Targus 4-Port Mobile USB Hub
Quicklinx: B3FNWS00 Mfr#: ACH111EU
The Targus 4-Port Mobile USB Hub is convenient for those who travel with their laptops and would like to connect to their peripherals via a USB port. Expand one USB port to four high-speed ports to connect and charge your iPod/MP3 player, smartphone or peripherals through the laptop. The USB cable never gets lost and stores inside of the hub for easy travel. Both compact and sleek, the Targus hub is portable and easy-to-use; simply plug and play.
Targus 4-Port Mobile USB Hub - hub
Hub
Subtype
USB
8.7 cm x 3.8 cm x 1.4 cm
30 g
Grey, black
Apple MacOS X 10.2 or later, Microsoft Windows 2000/XP/Vista/7
Europe
Hub
Enclosure Type
Desktop
Subtype
USB
4 x USB 2.0 Type A , 1 x USB Type B
Grey, black
1 x USB cable
RoHS
Europe
Additional Requirements
USB port
8.7 cm
3.8 cm
1.4 cm
30 g
B3FN C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
