The Targus 3D Protection case for the Samsung Tab A combines advanced engineered protection with all of the functionality you demand. This rugged Samsung Tab A case has a shock-absorbing, perfect fit, tray with internal ribbing plus a tough outer edge for added protection against everyday drops and dents. The tactile engineered design is easy to grip, with a water and dirt repellent exterior coating. The magnetic closure keeps your screen cover closed wherever the day may take you. The Targus 3D Protection Samsung Tab A case keeps your device safe while letting you realise its beauty and functionality.
- Targus 3D Protection - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 9.7"
- 18 cm x 2 cm x 25 cm
- 280 g
- Material
- Polyurethane
- Black
- Limited lifetime warranty
- Designed For
- Samsung Galaxy Tab A (9.7 in)
- 18 cm
- 2 cm
- 25 cm
- 280 g
- Material
- Polyurethane
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 9.7"
- Protection
- Shockproof, dirt-resistant, drop-proof
- Cover Type
- Flip cover
- Open Type
- Side
- Closure Type
- Magnetic closure
- Camera lens cutout, rugged, adjustable viewing angles, water repellent
- Cover Features
- Stand function
- Lifetime
- Designed For
