Targus 3D Protection Samsung Tab A 9.7  Tablet Case - Black
Quicklinx: BJYXWS00 Mfr#: THZ603GL
The Targus 3D Protection case for the Samsung Tab A combines advanced engineered protection with all of the functionality you demand. This rugged Samsung Tab A case has a shock-absorbing, perfect fit, tray with internal ribbing plus a tough outer edge for added protection against everyday drops and dents. The tactile engineered design is easy to grip, with a water and dirt repellent exterior coating. The magnetic closure keeps your screen cover closed wherever the day may take you. The Targus 3D Protection Samsung Tab A case keeps your device safe while letting you realise its beauty and functionality.
Targus 3D Protection - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
9.7"
18 cm x 2 cm x 25 cm
280 g
Material
Polyurethane
Samsung Galaxy Tab A (9.7 in)
18 cm
2 cm
25 cm
280 g
Material
Polyurethane
Carrying Case
Protective cover
Recommended Use
For tablet
9.7"
Protection
Shockproof, dirt-resistant, drop-proof
Cover Type
Flip cover
Open Type
Side
Closure Type
Magnetic closure
Camera lens cutout, rugged, adjustable viewing angles, water repellent
Cover Features
Stand function
Lifetime
