Targus 3D Protection iPad Air 2 Tablet Case - Light Grey
Quicklinx: BC1KWS00 Mfr#: THZ52201EU
The Targus 3D Protection iPad Air 2 case combines advanced engineered protection with all of the functionality you demand. This rugged iPad Air 2 case has shock-absorbing perfect fit tray with internal ribbing plus a tough outer edge for added protection against everyday drops and dents. The tactile engineered design is easy to grip, with a water and dirt repellent exterior coating. The elastic closure keeps your screen cover closed wherever the day may take you. The Targus 3D Protection iPad Air 2 case keeps your device safe while letting you realise its beauty and functionality.
  • Superior protection
    With a ribbed, shock-absorbing tray and a reinforced cover, the Targus 3D Protection case is engineered for high-performance protection. 3D Protection cases pass Mil. Spec. for 4 ft. drops, so you can entrust your iPad Air 2 to this protective case.
  • Ruggedized outer edge
    A rugged case is all about details. The 3D Protection case has bolstered edges to protect your iPad against accidental knocks with the furniture. The case's elastic band keeps the case shut when you're ready to go. Details keep your iPad secure.
  • Artistic structural design
    This is protection you can see. The structural beam design of the 3D Protection's cover repels dirt and water, giving you a firm surface to grip. It's a design you can depend on.
  • Adjustable angles for comfortable viewing and typing
    Your iPad is versatile - so is this case. The 3D Protection iPad Air 2 case offers adjustable viewing angles and the custom tray lets you access all of your device's buttons and ports. Protective to the core without the rugged price - that's the 3D Protection.
Targus 3D Protection Case - flip cover for tablet
Flip cover for tablet
17.8 cm x 1.4 cm x 24.4 cm
220 g
Europe
Material
Polyurethane
Grey
17.8 cm
1.4 cm
24.4 cm
220 g
Material
Polyurethane
Grey
Europe
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Waterproof, shockproof, scratch-resistant, dirt-resistant, drop-proof
Cover Type
Flip cover
Open Type
Side
Rugged, port cut-outs, buttons cutout
Cover Features
Stand function
Lifetime
