The Targus 3D Protection iPad Air 2 case combines advanced engineered protection with all of the functionality you demand. This rugged iPad Air 2 case has shock-absorbing perfect fit tray with internal ribbing plus a tough outer edge for added protection against everyday drops and dents. The tactile engineered design is easy to grip, with a water and dirt repellent exterior coating. The elastic closure keeps your screen cover closed wherever the day may take you. The Targus 3D Protection iPad Air 2 case keeps your device safe while letting you realise its beauty and functionality.
Superior protection
With a ribbed, shock-absorbing tray and a reinforced cover, the Targus 3D Protection case is engineered for high-performance protection. 3D Protection cases pass Mil. Spec. for 4 ft. drops, so you can entrust your iPad Air 2 to this protective case. -
Ruggedized outer edge
A rugged case is all about details. The 3D Protection case has bolstered edges to protect your iPad against accidental knocks with the furniture. The case's elastic band keeps the case shut when you're ready to go. Details keep your iPad secure. -
Artistic structural design
This is protection you can see. The structural beam design of the 3D Protection's cover repels dirt and water, giving you a firm surface to grip. It's a design you can depend on. -
Adjustable angles for comfortable viewing and typing
Your iPad is versatile - so is this case. The 3D Protection iPad Air 2 case offers adjustable viewing angles and the custom tray lets you access all of your device's buttons and ports. Protective to the core without the rugged price - that's the 3D Protection.
- Targus 3D Protection Case - flip cover for tablet
- Product Type
- Flip cover for tablet
- 17.8 cm x 1.4 cm x 24.4 cm
- 220 g
- Localisation
- Europe
- Material
- Polyurethane
- Grey
- Limited lifetime warranty
- 17.8 cm
- 1.4 cm
- 24.4 cm
- 220 g
- Material
- Polyurethane
- Grey
- Localisation
- Europe
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Waterproof, shockproof, scratch-resistant, dirt-resistant, drop-proof
- Cover Type
- Flip cover
- Open Type
- Side
- Rugged, port cut-outs, buttons cutout
- Cover Features
- Stand function
- Lifetime
