Targus 3-Button USB Optical Mouse - Black
Quicklinx: BBRQWS00 Mfr#: AMU89EU
The ergonomically designed Targus 3-Button USB Optical Mouse with Retractable USB Cord is the perfect device for both left handed and right handed users, whilst being small enough for travel and big enough for day-to-day desktop operations. The 1m USB cable adjusts to perfect length for ease of use and compact size makes the mouse fit comfortably into any pouch for easy storage. Utilising the latest optical technology, the 3-Button USB Optical Mouse provides precise tracking on most surfaces, through its 1,000 dpi optical sensor. The Optical Mouse also features a scroll-wheel for quicker viewing of documents, folders and websites.
  • USB retractable cable
    Avoid extra cable cluttering your workspace by adjusting the retractable cable to the desired length.
  • Ideal for travel or home office
    Small, compact design is perfect when space is limited.
  • Optical sensor technology
    The 1,000 dpi sensor utilizes the latest technology to ensure perfect responses to mouse movements.
  • Comfortable
    Ergonomically designed to support the palm to reduced wrist strain.
  • Plug and Play
    No hassle setup; simply plug into your computer's USB port.
Targus - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
5 cm x 9.5 cm x 3.3 cm
65 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Retractable cable, scrolling wheel
1 x USB cable - integrated - 1 m
Microsoft Windows 2000, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 / 8
Mouse
Orientation
5 cm
9.5 cm
3.3 cm
65 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Plug and Play
Additional Requirements
USB port
