Targus Corporate Traveler - notebook carrying backpack
Quicklinx: 7N90WS00 Mfr#: CUCT02BEU
Device Type: Laptop
Type: Backpack
Device Screen Size: 15.6
Colour: Black
Hurry, only 2 left in stock!
£66.73 ex VAT
£80.07 inc VAT
Smart and Hard Wearing. Corporate Traveller laptop bags offer outstanding laptop protection with patented SafePORT™ Protection systems. Built to withstand the wear and tear of everyday business travel with military grade nylon exterior. Excellent organisation with multiple pockets and storage options. Your carrying comfort is assured with moulded grab handle and flexible shoulder straps for shock absorption and evenly distribute weight across your shoulders.
  • Sturdy and secure
    Engineered with an advanced SafePort x D3O protection system on the base and sides of the laptop compartment, the shock absorbing polymer material offers the thinnest and most advanced protection against impact. D3O materials are made using a combination of advanced polymer chemistry and cutting-edge design. Soft and flexible, D3O absorbs and dissipates energy during an impact, dramatically reducing the amount of force transmitted to the laptop during a drop or fall.
  • Intuitive organization
    With a tablet compartment, removable accessory pouch, and two, front quick-access pockets, the Corporate Traveler Backpack is incredibly organized so that finding your pens, phone, and more is quick and easy. File dividers organize your documents and keep them looking fresh. Two mesh pockets on each side put your water bottle or travel mug at arm's length.
  • Contoured comfort
    This case is made for comfort. Thanks to a non-slip coating on the adjustable Equalizer shoulder strap, the briefcase stays put while you're walking through the airport or on public transit. Contoured and padded, it's shock-resistant and is made to bear the brunt of your gear's weight.
Notebook carrying backpack
Product Material
Polyester, polyurethane
35 cm x 21.5 cm x 50 cm
1.46 kg
Notebook Compatibility
15.6"
SafePORT Air Cushion System, water resistant, impact resistant, wear-resistant, lockable zipper, SafePort x D3O protection system
Carrying Strap
Trolley strap, top carrying handles, ergonomically designed shoulder straps
Product Material
35 cm
21.5 cm
50 cm
1.46 kg
15.6"
Notebook Compatibility Dimensions
38.7 cm x 26.5 cm x 2.5 cm
Additional Compartments
Personal accessories, 2x water bottle pockets, tablet, quick access front pocket, detachable accessory pouch
Carrying Strap
Closure Type
Zipper
Ventilated Back
Ventilated Back Type
Mesh material
30 litres
Limited warranty: - lifetime
Device Type: Laptop
Type: Backpack
Colour: Black
Brand: Targus
