The Tandberg RDX QuikStor cartridge delivers a rugged design that's shock-proof for maximum data protection and secure handling. Reliability is ensured with a load mechanism guaranteed for more than 10 K load/unload and a soft eject feature that protects data from unwanted eject errors. RDX QuikStor is compatible with all major backup applications so it fits seamlessly into your established backup routines. Backward/forward compatibility allows users to scale to higher capacities, meaning that tomorrow's higher capacity RDX cartridges will operate in today's RDX systems. Tandberg Data's RDX QuikStor meets the reliability, performance and business requirements for all backup and data archive applications-from professional workstations through to the low-end enterprise.
- Overland Tandberg RDX QuikStor - RDX HDD cartridge x 1 - 1 TB - storage media
- Storage media - RDX HDD cartridge
- Media Included Qty
- 1
- Native Capacity
- 1 TB
- Microsoft Certification
- Compatible with Windows 7
- Designed For
- Tandberg Data RDX QuikStation 4, RDX QuikStation 8, RDX QuikStor
- RDX HDD cartridge
- 1
Media
- Native Capacity
- 1 TB
- Designed For
