Product
Brand
Tandberg LTO-5 HH Drive - Internal Bare SAS
Quicklinx: 706HWS00 Mfr#: 3518-LTO
The availability of four generations of LTO tape drives simplifies the decision-it is the only option available for low cost requirements where capacity growth potential matches the data growth rates that businesses are facing today.
Since its introduction, LTO has been known as the enterprise-class technology of choice for medium to large size businesses and in medium and large size libraries. Tandberg Data's LTO-5 half-height (HH) drive brings enterprise-level performance to small and medium businesses at an affordable price. Tandberg Data's LTO drives are backed by more than 30 years of experience in linear tape technology research, design and manufacturing.
The Tandberg LTO half-height drives offer one of the industry's fastest transfer rates with high capacity to minimize backup times, Its compact size, provides simple and easy integration into all servers and workstation. The LTO technology makes it easy for users to standardize on a tape technology that meets today's data capacity requirements and ensures futures growth potential. LTO's six-generation roadmap, with four generations available today makes it a clear choice for small to medium businesses.
Tandberg LTO-5 HH - tape drive - LTO Ultrium - SAS-2
Tape drive
Recording Standard
LTO Ultrium 5
Enclosure Type
Internal
Interface Type
SAS-2
Key Features
Encryption
Storage Removable
LTO Ultrium - 5.25" x 1/2H
Storage Removable Capacity
1.5 TB (native) / 3 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 4, Ultrium 5
Data Transfer Rate (native)
140 MBps (504 GBph)
Data Transfer Rate (compressed)
280 MBps (1008 GBph)
3 years warranty
P/N: 3512-LTO
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 5
Enclosure Type
Internal
Interface Type
SAS-2
Key Features
Encryption
Built-in Devices
Led panel
Enclosure Colour
Storage Removable
Recording Standard
140 MBps (504 GBph)
Average Seek / Access Time
70 sec
Buffer Size
256 MB
1 x SAS-2 - 29 pin internal SAS (SFF-8482)
Compatible Bay
1 x front accessible - 5.25" x 1/2H
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15, AES-256
Limited warranty - replacement - 3 years - shipment - response time: 3 business days
10 °C
20 - 80%
P/N: 3512-LTO
