tado Smart Thermostat Starter Kit V3+ with Hot Water Control
Quicklinx: FC2RWS00 Mfr#: V3P-SK-ST01EK01IB01-TC-UK
Type: Thermostat kit
Compatible With: Alexa, Google Assistant, IFTTT, Siri
17 in stock
£166.66 ex VAT
£199.99 inc VAT
Express delivery Order within the next hour for delivery tomorrow
Starter Kit including Internet Bridge and Extension Kit
The Smart Thermostat is the central element in your living space. Here you can see the current temperature and set or alter the setpoint temperature. It does not matter which type of heating you have or from which manufacturer, the tado┬░ Smart Thermostat works with almost all systems: combi, system and heat-only boilers, conventional and condensing boilers, zoned systems, hydronic and electric underfloor systems and heat pumps.
The smart way to control your heating.
Make tado part of your connected home and create scenes with Apple HomeKit. Use Siri, Google Assistant or Amazon Echo to voice control your heating and create Applets with IFTTT to connect with other applications and smart devices.
tado shows you how warm it is at home, when your heating is on and how much you are saving. It also lets you control the heating from wherever you are.
Anytime, anywhere, any room.
The tado Smart Thermostat replaces an existing room thermostat or communicates wirelessly with the boiler via the included Extension Kit. The Extension Kit also enables you to control your hot water.
The Smart Thermostat Starter Kit with Hot Water Control is required for homes with a hot water tank, to control the hot water via the tado┬░ app. It is also required for homes that either have a wireless thermostat or no thermostat at all.
Compatible with 95% of central heating systems.
Compatible With: IFTTT
Compatible With: Siri
Brand: tado
Price Range Ex VAT: 150 - 300
