tado Smart Radiator Thermostat Starter Kit V3+ Vertical
Quicklinx: DX8ZWS00 Mfr#: V3P-SK-SRT01VIB01-TC-ML
Type: Radiator thermostat
Compatible With: Alexa, Google Assistant
24 in stock
£99.99 ex VAT
£119.98 inc VAT
Express delivery Order within the next 22 hours for delivery on Thursday
tado° Smart Thermostats V3+ - Smarter heating for more comfort and effortless savings
tado° is your Climate Assistant designed to make your live more comfortable by taking care of your comfort and savings at home. Get easy access and control of your heating system via the tado° app from anywhere, anytime. The unique skills of the Climate Assistant enable you to save up to 31% on your heating bill and achieve a healthier climate at home:
- Geofencing
- Open Window Detection
- Weather Adaptation
- New V3+: Air Comfort
- Smart Schedule
- New V3+: Auto-Assist: For even more comfort you can automate Geofencing and Open Window Detection (monthly subscription bookable in app, only £2.99/month, cancel anytime)
Additional features:
- Multi-room Control
- Hot water control
- Insightful reports
Seamless Smart Home integration & voice control with Amazon Alexa, Apple HomeKit, Google Assistant, & IFTTT.
What´s in the box?
tado° Smart Radiator Thermostat
2 AA batteries
Set of adapters
tado° Internet Bridge
UK power adapter
EU power adapter
USB cable
Ethernet cable
  • Ideal for communal heating
    Smart control of your radiators even if you do not have your own boiler.
  • More comfort
    Individually control multiple radiators for maximum comfort.
tado° Smart Radiator Thermostat (Vertical) - v3+ - Starter Kit - radiator thermostat
Radiator thermostat
Functions
Control heating systems
Power Source
Internet of Things (IoT) Platform
Apple HomeKit
Intelligent Assistant
Google Assistant, Alexa
Package Content
Bridge
Wireless
Frequency Band
868 MHz
Thermostat
LED
Matt white
5.2 cm x 5.2 cm x 7.8 cm
Radiator thermostat
Functions
Power Source
Package Content
Bridge
Wireless
Frequency Band
868 MHz
Light sensor, built-in temperature sensor, built-in humidity sensor, vertical mounting 6LoWPAN
Platform
Apple HomeKit
Compatible Services
IFTTT
Intelligent Assistant Compatible
Thermostat
Modes
Manual, programme
Display
LED
Matrix display
Aerial
Internal
Network cable, USB cable, connector kit, 6 radiator adapters
Product Material
Polycarbonate, ABS plastic
Matt white
Encryption Algorithm
AES-CCM, 2048-bit SSL, 256-bit SSL, TLS 1.2
Battery Required
2 x AA type
Warranty
ISO 9001, ISO 14001, RoHS, OHSAS 18001
5.2 cm
5.2 cm
7.8 cm
110 g
Dimensions & Weight Details
Radiator thermostat: 5.2 cm x 5.2 cm x 7.8 cm x 110 g , Bridge: 2.7 cm x 2.2 cm x 8.1 cm x 61 g
Shipping Width
17.5 cm
Shipping Depth
17.5 cm
Shipping Height
12.2 cm
Shipping Weight
1.045 kg
Brand: tado
Price Range Ex VAT: 50 - 100
