tado° Smart Thermostats V3+ - Smarter heating for more comfort and effortless savings
tado° is your Climate Assistant designed to make your live more comfortable by taking care of your comfort and savings at home. Get easy access and control of your heating system via the tado° app from anywhere, anytime. The unique skills of the Climate Assistant enable you to save up to 31% on your heating bill and achieve a healthier climate at home:
- Geofencing
- Open Window Detection
- Weather Adaptation
- New V3+: Air Comfort
- Smart Schedule
- New V3+: Auto-Assist: For even more comfort you can automate Geofencing and Open Window Detection (monthly subscription bookable in app, only £2.99/month, cancel anytime)
Additional features:
- Multi-room Control
- Hot water control
- Insightful reports
Seamless Smart Home integration & voice control with Amazon Alexa, Apple HomeKit, Google Assistant, & IFTTT.
What´s in the box?
tado° Smart Radiator Thermostat
2 AA batteries
Set of adapters
tado° Internet Bridge
UK power adapter
EU power adapter
USB cable
Ethernet cable
The smart way to control your heating. tado° is your Climate Assistant that ensures a comfortable and healthy climate, whilst considerably reducing your energy consumption. The intuitive smartphone app and smart home integrations enable you to control your heating from anywhere and more efficiently than ever before. It works with voice assistants too, so when you’re snuggled up on the sofa, you won’t even need to reach for your phone to make your home all toasty. Plus, it’s compatible with both combi boilers and models with separate tanks, and this model also comes with the hub, so you can get started straight away.
Smart Skills
Tado° detects open windows, incorporates weather forecasts and helps you adjust the temperature based on your location. Tado° also lets you set heating and cooling schedules to suit your routine. Tado° gives you insights into the temperature and humidity in your home. It advises you on how to keep the air in your home healthy. Tado puts you in control of your heating or air conditioning anytime, from anywhere via the app.
Ideal for communal heating
Smart control of your radiators even if you do not have your own boiler. -
More comfort
Individually control multiple radiators for maximum comfort.
- tado° Smart Radiator Thermostat (Vertical) - v3+ - Starter Kit - radiator thermostat - matt white
- Product Type
- Radiator thermostat
- Functions
- Control heating systems
- Integrated Sensors
- Humidity, temperature
- Power Source
- Battery
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Google Assistant, Alexa
- Package Content
- Bridge
- Connectivity
- Wireless
- Frequency Band
- 868 MHz
- Display
- LED
- Matt white
- 2-year warranty
- 5.2 cm x 5.2 cm x 7.8 cm
- Product Type
- Functions
- Power Source
- Battery
- Package Content
- Bridge
- Connectivity Technology
- Wireless
- Frequency Band
- 868 MHz
- Display
- LED
- Light sensor, vertical mounting 6LoWPAN
- Platform
- Apple HomeKit
- Compatible Services
- IFTTT
Thermostat
- Modes
- Manual, programme
- Matrix display
Aerial
- Form Factor
- Internal
- Form Factor
- AA type
- Battery Included
- Required Qty
- 2
- Included Accessories
- Network cable, USB cable, connector kit, 6 radiator adapters
- Product Material
- Polycarbonate, ABS plastic
- Matt white
- Encryption Algorithm
- AES-CCM, 2048-bit SSL, 256-bit SSL, TLS 1.2
- Warranty
- 2-year warranty
- ISO 9001, ISO 14001, RoHS, OHSAS 18001
- 5.2 cm
- 5.2 cm
- 7.8 cm
- 110 g
- Dimensions & Weight Details
- Radiator thermostat: 5.2 cm x 5.2 cm x 7.8 cm x 110 g , Bridge: 2.7 cm x 2.2 cm x 8.1 cm x 61 g
- Shipping Width
- 17.5 cm
- Shipping Depth
- 17.5 cm
- Shipping Height
- 12.2 cm
- Shipping Weight
- 1.045 kg
