tado Smart Radiator Thermoastat - Duo Pack - Vertical Mounting
Quicklinx: FLQXWS00 Mfr#: V3P-2SRT01V-TC-ML
Hurry, only 2 left in stock!
£99.99 ex VAT
£119.98 inc VAT
The Smart Radiator Thermostat uses your phone's location to control a room radiator. It turns the heating down when no one is home and starts to pre-heat when it detects the first person returning.
If you already have a Smart Radiator Thermostat - Starter Kit or a Smart Thermostat - Starter Kit of any version (V2/V3/V3+) then you can supplement these with additional Smart Radiator Thermostats to independently control multiple radiators.
Self install
It's easy to install the Smart Radiator Thermostat yourself. Simply unscrew the old radiator thermostat and install the Smart Radiator Thermostat with the help of the Starter Kit adapter. Don’t worry, water cannot leak during installation.
  • Ideal for communal heating
    Smart control of your radiators even if you do not have your own boiler.
  • More comfort
    Individually control multiple radiators for maximum comfort.
tado° Smart Radiator Thermostat - vertical - radiator thermostat
Radiator thermostat
Packaged Quantity
2 (specifications are for single item)
Functions
Control heating systems
Power Source
Intelligent Assistant
Google Assistant, Alexa
Wireless
Frequency Band
868 MHz
Thermostat
LED
Matt white
5.2 cm x 5.2 cm x 7.8 cm
Packaged Quantity
Radiator thermostat
Functions
Power Source
Wireless
Frequency Band
868 MHz
Light sensor, built-in temperature sensor, built-in humidity sensor
Internet of Things (IoT)
Compatible Services
IFTTT
Intelligent Assistant Compatible
Thermostat
Display
LED
Matrix display
Aerial
Internal
6 radiator adapters
Product Material
Polycarbonate, ABS plastic
Matt white
Encryption Algorithm
AES-CCM, 2048-bit SSL, 256-bit SSL, TLS 1.2
Battery Required
2 x AA type
Warranty
ISO 9001, ISO 14001, RoHS, OHSAS 18001
5.2 cm
5.2 cm
7.8 cm
110 g
Shipping Width
17.4 cm
Shipping Depth
7 cm
Shipping Height
17.4 cm
Shipping Weight
604 g
Brand: tado
Price Range Ex VAT: 50 - 100
