Product
Brand
tado Smart Heating Thermostat
Quicklinx: C015WS00 Mfr#: 10077
The Smart Thermostat is the central element in your living space. Here you can see the current temperature and set or alter the setpoint temperature. It does not matter which type of heating you have or from which manufacturer, the tado° Smart Thermostat works with almost all systems: combi, system and heat-only boilers, conventional and condensing boilers, zoned systems, hydronic and electric underfloor systems and heat pumps.
tado° Smart Thermostat - thermostat
Thermostat
Functions
Control heating systems
Internet of Things (IoT) Platform
Apple HomeKit
Wireless
Frequency Band
868 MHz
Supported Host Device OS
iOS, Android, Windows Phone
Thermostat
LCD
Matt white
10.4 cm x 1.9 cm x 10.4 cm
Thermostat
Functions
Wireless
Frequency Band
868 MHz
Android 2.3 or later, Windows Phone OS 8.1, iOS 7.1 or later
Platform
Apple HomeKit
Communications Type
Product-to-product
Communications Technology
6LoWPAN
Intelligent Assistant Compatible
Siri, Alexa
Voice Controlled
Indirect
Thermostat
Modes
Auto, manual, programme
Display
LCD
Backlit display, matrix display
3 AAA batteries, screws, screwdriver
Matt white
Encryption Algorithm
256-bit SSL, TLS 1.2
Battery Required
3 x AAA type
RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2014/35/EU, R&TTE Directive 1999/5/EC
10.4 cm
1.9 cm
10.4 cm
132 g
