Synology USB Station 2
Quicklinx: 8818WS00 Mfr#: USB STATION 2
USB Station 2 is designed to provide a cost-effective solution for USB storage sharing, multimedia center, and print server for home and small workgroup. The operating system delivers rich features for multimedia enjoyments, Internet file sharing, budget print server, and energy-saving options.
  • Plug-and-Play file sharing
    USB Station 2 is ready to use right out of the box by simply plugging in any USB storage device. The built-in file browser allows you to start sharing multimedia with family members or group projects with colleagues right away, with the ease of file navigation through a web browser. Sharing files among Windows, Mac, and Linux users highly increases the work efficiency in a platformmixed environment. Not only does it reduce your carbon footprint, but it also helps create a noiseless home or working environment.
  • Your own entertainment center
    The eMule download engine allows search-n-download capability with a web-browser without installing additional desktop applications. Audio Station supports music, Internet radio stations, and iPod playback with the optional speakers. Streaming mode allows your music to be shared with multiple users over the Intranet or Internet. DS audio allows you to stream music stored on DiskStation to your iPhone, iPod touch or Android phone wherever Internet access is available. You can enjoy terabytes of music anytime anywhere. iTunes is an easy way to share music with other iTunes clients over the network. Password protection prevents unauthorized sharing.
  • USB printer sharing for everyone
    USB Station 2 supports up to two USB printers simultaneously. The USB printer sharing capability minimizes your cost by sharing printing resources throughout the home or the office. No professional IT personnel are required to set up the print server in your home or office, as the add printer wizard simplifies setup process on your local computer.
Synology USB Station 2 - device server
Device server
External
800 MHz
RAM
128 MB
Ethernet, Fast Ethernet, Gigabit Ethernet, USB 2.0
12.2 cm x 11.1 cm x 4.6 cm
147 g
Device server
12.2 cm
11.1 cm
4.6 cm
147 g
Processor / Memory / Storage
Processors Installed
800 MHz
RAM
128 MB
External
Wired
Network / Transport Protocol
FTP
Remote Management Protocol
HTTP, HTTPS
Print server, IPv6 support, firmware upgradable
Encryption Algorithm
SSL, TLS
2 x USB 2.0 - Type A , 1 x 1000Base-T - RJ-45
FCC Class B certified, RoHS, BSMI Class B
External power adapter
5 Watt
5 °C
35 °C
5 - 95%
