Synology SNV3400 400GB M.2 NVMe SSD
Quicklinx: FW6DWS00 Mfr#: SNV3400-400G
Form Factor: M.2 2280
Capacity: 400GB
Interface: PCI Express 3.0 x4 (NVMe)
Type: Internal hard drive
£115.04 ex VAT
£138.04 inc VAT
The Synology SNV3400 NVMe SSD is designed to handle tough caching workloads in a 24/7 multi-user environment. Its durable I/O performance boosts system responsiveness and speeds up handling of frequent access data, providing a streamlined storage experience while minimizing service disruptions to your Synology NAS.
Designed for use in Synology systems only, warranty claims will be rejected when used in non-Synology devices
  • Consistently fast caching for 24/7 environments
    Built for system cache, the Synology SNV3400 pushes up random I/O performance and reduces latency in demanding 24/7 environments. It offers durable caching and it is suitable for multimedia post-production and database applications.
  • Data integrity safeguards
    The Synology SNV3400 integrates end-to-end data protection to safeguard data integrity over the entire transfer path.
  • Timely notifications
    Plan further ahead for uninterrupted system performance and longevity with timely notifications.
Synology SNV3400-400G - solid state drive - 400 GB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal
400 GB
M.2 2280
End-to-end data protection, NVM Express (NVMe)
22 mm x 80 mm x 3.5 mm
5-year warranty
Disk Station DS1618+, DS1819+, DS2419+; RackStation RS2818RP+, RS820+, RS820RP+
400 GB
M.2 2280
22 mm
80 mm
3.5 mm
Performance
Drive Writes Per Day (DWPD)
0.68
SSD Endurance
500 TB
Internal Data Rate
3100 MBps (read) / 550 MBps (write)
Maximum 4KB Random Write
40000 IOPS
Maximum 4KB Random Read
205000 IOPS
Reliability
MTBF
1,800,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
3.2 Watt (read) , 3.2 Watt (write) , 2 Watt (idle)
VCCI, BSMI, FCC, RoHS, KC, RCM
Limited warranty - 5 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Synology Disk Station DS1618+, DS1819+, DS2419+ , Synology RackStation RS2818RP+, RS820+, RS820RP+
Capacity: 400GB
Brand: Synology
