Synology 12 Bay NAS Rack Enclosure (SA3400)
The Synology SA3400 is a 12-bay rackmount NAS designed for large and extensive scaling of data storage. Its comprehensive data protection technologies, including High Availability, hybrid cloud backup, and server or virtual machine backup approaches, make it a reliable server for massive storage deployment.
Synology NAS Rack Enslosure (SA3400) Key Features
A highly scalable rackmount NAS to aptly accommodate large businesses' needs for scalability, suitable for video post-production and massive surveillance deployment
TCO-optimized storage companion, offering various and flexible support for both SAS and SATA drives
Scale up to 180/96 drives when connected with 7 RX2417sas/RX1217sas
Built-in dual 10GbE and quad 1GbE ports with failover and Link Aggregation support
Elastic expandability with dual PCIe 3.0 x8 slots for installing additional 10/25GbE network interface cards
Effortless data protection for your physical server, virtual machines, and cloud services through Synology Active Backup Suite
Advanced iSCSI storage supports various virtualization deployment, including VMware vSphere®, Windows Hyper-V®, Citrix XenServer®, and OpenStack Cinder®
Backed by Synology's 5-year limited warranty
Small-to-hyperscale flexibility
Scalable up to 180/96 drives delivering more than 1.5 petabytes raw capacity, SA3400 can easily fulfill extensive storage needs, including video post-production and massive surveillance deployment. -
Supercharge network performance effortlessly
Built-in dual 10GbE Ethernet ports and dual PCIe 3.0 slots provide high-speed network transmission with additional network interface cards' expansion. -
Btrfs: next-generation storage efficiency
Btrfs file system introduces the most advanced storage technologies to meet the management needs of modern large scale businesses. -
Fully certified storage virtualization solutions
Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface.
- Synology SA3400 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- 48.2 cm x 72.4 cm x 8.8 cm
- 14.5 kg ()
- Processor
- 1 x Intel Xeon D-1541 2.1 GHz (8-core)
- Storage Controller
- RAID RAID RAID 0, 1, 5, 6, 10, JBOD, RAID F1
- Networking
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- IP Cameras Supported
- 100
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
- 5-year warranty
- NAS server
- Host Connectivity
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 48.2 cm
- 72.4 cm
- 8.8 cm
- 14.5 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- 8-core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.7 GHz
- RAM
- 16 GB (installed) / 128 GB (supported) - DDR4
- Registered, ECC
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
- Data Link Protocol
- PPTP, L2TP, iSCSI, SMTP, FTP, SMB, NFS, HTTPs
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH, SMTP, LDAP
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, LDAP support, wake on LAN (WOL), antivirus analysis, High Availability, download client, anti-malware protection, Access Control List (ACL) support, e-mail server, reset button, bandwidth control, surveillance station, VPN Server, Link Aggregation, failover protection, DLNA support, OpenStack compatible, B-tree file system (Btrfs), file station, EXT4 file system, iSCSI LUN clone/snapshot, Windows ODX, MailPlus server
- Encryption Algorithm
- AES-NI
Security DVR
- 100
- Compression Format
- MJPEG, H.264, H.265
- Image Resolution
- 1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x Ethernet 10Gb - RJ-45
- Built-in 4 cooling fans
- VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM
- Included Accessories
- Accessory pack
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- 137.17 Watt
- Power Provided
- 500 Watt
- OS Required
- Limited warranty - 5 years
- 0 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 49.8 dBA
Hard Drives
Synology 8TB HAS5300 3.5" SAS Hard Drive | In Stock | £239.58 |
Synology 12TB HAS5300 3.5" SAS Hard Drive | In Stock | £372.67 |
Synology 16TB HAS5300 3.5" SAS Hard Drive | In Stock | £533.55 |
