Featuring a high-availability design, next-generation snapshot technology, and massive scalability up to 180 drives, RXD1215sas delivers the secure, reliable, and superior performance storage solution for enterprises seeking business continuity and point-in-time data recovery.
Massive scalability up to 180 drives
Up to fifteen RXD1215sas can be connected to the dual RC18015xs+ computing nodes, accommodating massive scalability up to 180 drives and maximum raw storage beyond 1PB. The shared storage architecture eliminates the need for data replication over the network, in addition to drastically reducing deployment costs. -
Hardware redundancy enhances system uptime
In addition to the active/passive architecture, RXD1215sas is equipped with redundant hardware components, such as power supply units, SAS modules, SAS connection cables, system fans, LAN ports, and even the Heartbeat connection. In the event of component failure, the system continues operating normally while replacement parts are obtained and installed. -
High-availability cluster design
By combining two computing servers and multiple storage units into a single high-availability cluster, RXD1215sas delivers unyielding reliability and data availability. With the active/passive structure, services are automatically switched over to one server if the other unexpectedly goes offline, helping your business avoid costly downtime.
- Synology RackStation RXD1215SAS - hard drive array - TAA Compliant
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Total Array Capacity
- 24 TB
- Interface
- SAS
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- Supported Drives
- SAS
- Storage Controller
- RAID (SAS) - RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 12 x 2 TB HDD - hot-swap
- Power
- AC 120/230 V - 50 - 60 Hz
- Power Redundancy
- TAA Compliant
- 43 cm x 69.2 cm x 8.8 cm
- 18 kg
- 5-year warranty
- Hard drive array
- Enclosure Type
Chassis
- 12
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SAS
Storage
- 24 TB
- HDD Array External Interface
- SAS
Storage Controller
- RAID
- Interface Type
- SAS
- Max Storage Devices Qty
- 12
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 2 TB
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 2 x SAS (input) , 2 x SAS (output)
- Built-in 4 cooling fans
- FCC Class A certified, RoHS, BSMI Class A
- TAA Compliant
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 248 Watt
- Power Provided
- 500 Watt
- 43 cm
- 69.2 cm
- 8.8 cm
- 18 kg
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 5 - 95%
