Synology RX418 4TB (4 x 1TB RED) 4 Bay Rack Mountable NAS
Quicklinx: DBJCWS00 Mfr#: RX418/4TB-RED
Storage capacity expansion
When the storage capacity on Synology 1U RackStation reaches its limit, Synology expansion unit RX418 provides easy capacity expansion by adding 4 3.5"/2.5" SATA drives to the system. Synology RX418 can also be used as a dedicated local backup destination of Synology 1U RackStation for comprehensive data protection.
Reliable plug-and-play design
Simply connect Synology RX418 to corresponding Synology RackStation and it is ready to use. Drives in the connected Synology RX418 operate as though they were internal to the connected Synology NAS and can be managed directly by Synology DiskStation Manager (DSM), with no additional software installation required.
Green and easy to manage
Award-winning Synology DSM provides an intuitive user interface for easy system management. Drive hibernation can be configured in DSM to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the installed drives.
4TB (4 x 1TB) WD Red Hard Drives included
  • Storage capacity expansion
    When the storage capacity on Synology RackStation reaches its limit, Synology expansion unit RX418 provides easy capacity expansion by adding SATA drives to the system. Synology RX418 can also be used as a dedicated local backup destination of Synology RackStation for comprehensive data protection.
  • Reliable plug-and-play design
  • Green and easy to manage
Synology RX418 Expansion Unit - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 1U
4 (installed) / 4 (max)
Supported Drives
SATA-600
Built-in Devices
Led panel
Hard Drive
4 x 1 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
43.05 cm x 29 cm x 4.4 cm
3-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 1U
Chassis
Built-in Devices
Led panel
4
Supported Devices / Modules Qty
4
Supported Drives
SATA-600
CPU
No CPU
Hard Drive
HDD - hot-swap
4 x 1 TB
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x eSATA - 7 pin external Serial ATA
Built-in 3 cooling fans, lockable tray, deep sleep mode
1 x eSATA cable
FCC Class B certified, VCCI, RoHS, BSMI Class A, KC, EAC, RCM
2 x keys, rack mounting kit, screws, accessory pack
Internal power supply
23.26 Watt
Power Provided
100 Watt
43.05 cm
29 cm
4.4 cm
Limited warranty - 3 years
35 °C
5 - 95%
Sound Emission
25.1 dBA
