Storage capacity expansion
When the storage capacity on Synology 1U RackStation reaches its limit, Synology expansion unit RX418 provides easy capacity expansion by adding 4 3.5"/2.5" SATA drives to the system. Synology RX418 can also be used as a dedicated local backup destination of Synology 1U RackStation for comprehensive data protection.
Reliable plug-and-play design
Simply connect Synology RX418 to corresponding Synology RackStation and it is ready to use. Drives in the connected Synology RX418 operate as though they were internal to the connected Synology NAS and can be managed directly by Synology DiskStation Manager (DSM), with no additional software installation required.
Green and easy to manage
Award-winning Synology DSM provides an intuitive user interface for easy system management. Drive hibernation can be configured in DSM to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the installed drives.
4TB (4 x 1TB) WD Red Hard Drives included
When the storage capacity on Synology RackStation reaches its limit, Synology expansion unit RX418 provides easy capacity expansion by adding SATA drives to the system. Synology RX418 can also be used as a dedicated local backup destination of Synology RackStation for comprehensive data protection. -
Simply connect Synology RX418 to corresponding Synology RackStation and it is ready to use. Drives in the connected Synology RX418 operate as though they were internal to the connected Synology NAS and can be managed directly by Synology DiskStation Manager (DSM), with no additional software installation required. -
- Synology RX418 Expansion Unit - storage enclosure
- Storage enclosure
- Enclosure Type
- Rack-mountable - 1U
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- Supported Drives
- SATA-600
- Built-in Devices
- Led panel
- Hard Drive
- 4 x 1 TB HDD - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- 43.05 cm x 29 cm x 4.4 cm
- 3-year warranty
- Storage enclosure
- Enclosure Type
Chassis
- Built-in Devices
- Led panel
- 4
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-600
- CPU
- No CPU
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 1 TB
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 1 x eSATA - 7 pin external Serial ATA
- Built-in 3 cooling fans, lockable tray, deep sleep mode
- Cables Included
- 1 x eSATA cable
- FCC Class B certified, VCCI, RoHS, BSMI Class A, KC, EAC, RCM
- Included Accessories
- 2 x keys, rack mounting kit, screws, accessory pack
- Power Device
- Internal power supply
- Voltage Required
- 23.26 Watt
- Power Provided
- 100 Watt
- 43.05 cm
- 29 cm
- 4.4 cm
- Limited warranty - 3 years
- 0 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 25.1 dBA
