Your basket is empty
Synology RX415 4TB-Red 4 Bay NAS
Quicklinx: B0K3WS00 Mfr#: RX415/4TB-RED
Type: Storage enclosure
Controller Type: None
£660.91 ex VAT
£793.09 inc VAT
Synology RX415 delivers an effortless volume expansion and data backup solution for Synology's 1U RackStation servers by providing an additional 4 drive slots. With its short-depth chassis design, RX415 ensures easy installation and deployment in 2-post racks and wall mount racks.
Synology RX415 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 1U
Total Array Capacity
4 TB
4 (installed) / 4 (max)
Supported Drives
SATA-600
Hard Drive
4 x 1 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
43.05 cm x 29 cm x 4.4 cm
4.23 kg
3 years warranty
Storage enclosure
Enclosure Type
Rack-mountable - 1U
Chassis
4
Supported Devices / Modules Qty
4
Supported Drives
SATA-600
Storage
4 TB
Hard Drive
HDD - hot-swap
4 x 1 TB
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x eSATA - 7 pin external Serial ATA
Built-in 3 cooling fans
1 x eSATA cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
Power Provided
150 Watt
43.05 cm
29 cm
4.4 cm
4.23 kg
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Brand: Synology
Price Range Ex VAT: 500 - 750
