Product
Brand
Synology RX415 4-bay Rack Expansion Unit
Quicklinx: 9QS5WS00 Mfr#: RX415
Synology RX415 delivers an effortless volume expansion and data backup solution for Synology's 1U RackStation servers by providing an additional 4 drive slots. With its short-depth chassis design, RX415 ensures easy installation and deployment in 2-post racks and wall mount racks.
Synology RX415 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 1U
Max Supported Capacity
24 TB
SATA 3Gb/s
4 (max)
Supported Drives
SATA-300
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
0 - hot-swap
AC 120/230 V - 50/60 Hz
43.05 cm x 29 cm x 4.4 cm
4.23 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 1U
Chassis
Supported Devices / Modules Qty
4
Supported Drives
SATA-300
Storage
24 TB
HDD Array External Interface
SATA 3Gb/s
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
Hot-swap
0
Expansion Bays
4 (total) / 4 (free) x hot-swap
1 x SATA 3Gb/s - 7 pin external Serial ATA
Built-in 3 cooling fans
1 x eSATA cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
Power Provided
150 Watt
43.05 cm
29 cm
4.4 cm
4.23 kg
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
