Synology RX1216SAS 12 Bay Rack Expansion Unit
Quicklinx: BKBDWS00 Mfr#: RX1216SAS
Type: Hard drive array
Controller Type: RAID
£1,964.97 ex VAT
£2,357.96 inc VAT
Synology RX1216sas delivers an effortless storage capacity expansion solution for Synology RackStation RS18016xs+ by adding 12 drives on-the-fly while directly connected.
Synology RX1216sas - hard drive array - TAA Compliant
Hard drive array
Enclosure Type
Rack-mountable
Max Supported Capacity
96 TB
SAS
0 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS
Storage Controller
RAID (SATA 6Gb/s / SAS)
Hard Drive
No HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
TAA Compliant
43 cm x 69.2 cm x 8.8 cm
13.5 kg
5-year warranty
Hard drive array
Enclosure Type
Rack-mountable
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS
Storage
96 TB
HDD Array External Interface
SAS
CPU
No CPU
Storage Controller
RAID
Channel Qty
12
Interface Type
SATA 6Gb/s / SAS
Data Transfer Rate
600 MBps
Hard Drive
No HDD - hot-swap
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
2 x SAS (input) , 2 x SAS (output)
2 x SAS cable
FCC Class A certified, RoHS, BSMI Class B, BSMI Class A
TAA Compliant
2 x internal power supply
Max Supported Qty
2
Power Redundancy
67.31 Watt
Power Provided
500 Watt
43 cm
69.2 cm
8.8 cm
13.5 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
45.1 dBA
Brand: Synology
Price Range Ex VAT: £1500+
