Product
Brand
Synology RX1214 24TB Red Pro 12 Bay EXP
Quicklinx: B0JRWS00 Mfr#: RX1214/24TB RED PRO
Synology RX1214 delivers an effortless solution for volume expansion and data backup for Synology RackStation. The RX1214 seamlessly scales up the storage capacity of the Synology RackStation by an additional 12 hard drives on-the-fly when connected directly to an expansion cable.
Synology RX1214 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
24 TB
12 (installed) / 12 (max)
Supported Drives
SATA-600
Hard Drive
12 x 2 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
44.5 cm x 57 cm x 8.8 cm
3 years warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
Storage
24 TB
Hard Drive
HDD - hot-swap
12 x 2 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x InfiniBand
Built-in 4 cooling fans
1 x InfiniBand cable
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Internal power supply
108 Watt
Power Provided
400 Watt
44.5 cm
57 cm
8.8 cm
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
40.5 dBA
