Synology RS818+/4TB-RED 4 Bay NAS
Quicklinx: DXWBWS00 Mfr#: RS818+/4TB-RED
  • Atom
Synology RackStation comes with a quad-core processor with the AES-NI hardware encryption engine, quad 1GbE LAN ports, and optional 10GbE NIC support. It provides both high performance and a scalable storage solution for sharing files across different platforms, centralizing data backups, and protecting critical assets.
  • Built for high service reliability
    The server comes with four 1 GbE LAN ports to support Link Aggregation and failover. Synology High Availability support provides a reliable active/passive server cluster, keeping data and services online.
  • Real-time collaboration on your private cloud
    Office is a collaboration package combining the convenience and usability of public clouds with the data privacy and security guaranteed by private clouds. It allows you to work seamlessly together on documents and spreadsheets in a protected environment.
  • Empower your storage with speedier performance
    The server allows network and memory upgrades to boost system performance.
Synology RackStation RS818+ - NAS server - 4 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
4 TB
Max Supported Capacity
48 TB
4 (installed) / 4 (max)
43.05 cm x 45.76 cm x 4.4 cm
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
Hard Drive
4 x 1 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
4 TB
48 TB
43.05 cm
45.76 cm
4.4 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
(supported) 2 GB (installed) / 16 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
HDD - hot-swap
4 x 1 TB
Network / Transport Protocol
PPTP, L2TP, IPSec, iSCSI, FTP, DNS, SMB, NFS, SFTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, SFTP
Network Services Compatibility
Microsoft Active Directory (AD), DNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), Syslog support, antivirus analysis, High Availability, IP address filtering, backup server, download client, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, RADIUS support, SSH support, iTunes server, Samba support, FTP server, BitTorrent Client, reset button, bandwidth control, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, eMule client, VPN Server, Dropbox support, Link Aggregation, Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, file station, OpenStack Swift-compatible, Baidu cloud support, cloud station server, MailPlus server, Amazon S3 support
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
40
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 2.0 x8 , 2 (total) / 1 (free) x SO-DIMM 204-pin
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x serial (management) - DB-9
Audible alarm, wake on LAN, built-in 3 cooling fans, scheduled power on/off
VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM
Internal power supply
Power Provided
150 Watt
Software Included
Synology Assistant
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
