Synology RS818+ 16TB (4 x 4TB IWPRO) 4 Bay Rack Mountable
Quicklinx: DBL3WS00 Mfr#: RS818+/16TB-IWPRO
  • Atom
£1,420.95 ex VAT
£1,705.14 inc VAT
Powerful and scalable storage solution
Synology RackStation RS818+/RS818RP+ comes with a quad-core processor with the AES-NI hardware encryption engine, quad 1GbE LAN ports, and optional 10GbE NIC support. It provides both high performance and a scalable storage solution for sharing files across different platforms, centralizing data backups, and protecting critical assets.
Built for high service reliability
RS818+ comes with four 1Gbe LAB ports to supporrt Link Aggretion and failover. Synology High Availability support provides a reliable active/passive server cluster, keeping data and services online. Furthemore, RS818RP+ is equipped with redundant power supplies to deliver increased service continuty.
Real-time collaboration on your private cloud
Office is a collaboration package combining the convenience and usability of public clouds with the data privacy and security guaranteed by private clouds. It allows you to work seamlessly together on documents and spreadsheets in a protected environment.
Fully certified storage virtualization solutions
Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface. VMware vSphere 6 and VAAI integration helps offload storage operations and optimizes computation efficiency. Windows Offloaded Data Transfer (ODX) speeds up data transfer and migration rate. OpenStack Cinder support turns your Synology NAS into a block-based storage component.
16TB (4 x 4TB) WD IWPRO Hard Drive included!
  • Built for high service reliability
    The server comes with four 1 GbE LAN ports to support Link Aggregation and failover. Synology High Availability support provides a reliable active/passive server cluster, keeping data and services online.
  • Real-time collaboration on your private cloud
  • Empower your storage with speedier performance
    The server allows network and memory upgrades to boost system performance.
Synology RackStation RS818+ - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
16 TB
Max Supported Capacity
48 TB
4 (installed) / 4 (max)
43.05 cm x 45.76 cm x 4.4 cm
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
Hard Drive
4 x 4 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
16 TB
48 TB
43.05 cm
45.76 cm
4.4 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
RAM
2 GB (installed) / 16 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
HDD - hot-swap
4 x 4 TB
Network / Transport Protocol
PPTP, L2TP, iSCSI, FTP, DNS, SMB, NFS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
DNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP
Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), antivirus analysis, High Availability, backup server, download client, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, RADIUS support, SSH support, iTunes server, FTP server, BitTorrent Client, reset button, bandwidth control, surveillance station, PXE support, Apple Time Machine compatible, eMule client, Google Drive support, scheduler, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, DLNA support, file station, cloud station server, MailPlus server
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
40
Compression Format
H.264
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 2.0 x8 , 2 x SO-DIMM 204-pin
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x serial (management) - DB-9
Wake on LAN, built-in 3 cooling fans
FCC Class A certified, VCCI, CCC, RoHS, BSMI Class A, KC, EAC, RCM
Internal power supply
45.28 Watt
Power Provided
150 Watt
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
28.5 dBA
Brand: Synology
Price Range Ex VAT: 1000 - 1500
