Synology RS4017xs+ 128TB (16x8TB SGT-IW PRO) 16 Bay Rack Unit
Quicklinx: CS7DWS00 Mfr#: RS4017XS+/128TB-IW PRO
  • Xeon
RS4017xs+ provides rock-solid storage solution with ultra-high performance at over 690,000 sequential read IOPS and 4,900 MB/s sequential read throughput. DDR4 ECC UDIMM and 10 GbE connectivity guarantees data accuracy and performance for mission-critical environment.
  • High availability
    Ensures seamless transition between clustered servers in the event of server failure with minimal impact to applications.
  • Hyper backup
    Minimize storage space required for backing up data in multiple versions with block-level incremental backup and cross-version deduplication.
  • Cloud station suite
    Automatic cross-platform data synchronization with file version control.
  • CMS
    Manage multiple Synology NAS servers simultaneously through a centralized interface to increase administrative efficiency and flexibility.
  • MailPlus
    Set up a secure, reliable and private mail server with stylish and intuitive user interface.
  • Collaboration suite
    Synology Office, Calendar and Chat guarantee a secure and high-performance private communication and user-friendly content organization.
Synology RackStation RS4017XS+ - NAS server - 128 TB
NAS server
Host Connectivity
10GBase-T
Enclosure Type
Rack-mountable - 3U
Total Storage Capacity
128 TB
16 (installed) / 16 (max)
48.2 cm x 65.65 cm x 13.23 cm
17.4 kg ()
1 x Intel Xeon D-1541 2.1 GHz (8-core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
16 x 8 TB
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
IP Cameras Supported
90
RAM
8 GB
Power Redundancy
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
5-year warranty
NAS server
Host Connectivity
10GBase-T
Enclosure Type
Rack-mountable - 3U
128 TB
48.2 cm
65.65 cm
13.23 cm
17.4 kg ()
Processor / Memory
Processors Installed
Number of Cores
8-core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
16 x 8 TB
Network / Transport Protocol
PPTP, L2TP, iSCSI
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, wake on LAN (WOL), Syslog support, Access Control List (ACL) support, 3 fans, Link Aggregation, scheduler, failover protection, OpenStack compatible
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
90
Expansion Bays
16 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
4 (total) / 3 (free) x DIMM 288-pin , 2 (total) / 2 (free) x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 2 x Ethernet 10Gb - RJ-45 , 1 x serial - DB-9 , 2 x InfiniBand
Citrix Ready, VMware Ready
FCC Class A certified, RoHS, BSMI Class A
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
136.4 Watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
44.7 dBA
