Designed for large-scale businesses, RS3617xs provides high-performance throughput with comprehensive business applications. RS3617xs allows you to centralize storage, simplify data management, and deploy virtualization solutions with minimal time required for setup and maintenance.
High-performance NAS server
RS3617xs delivers high performance at over 3,263 MB/s sequential throughput and 333,941 IOPS under a RAID 5 configuration1 with 10GbE Link Aggregation. Equipped with 4GB DDR3 ECC RAM, RS3617xs ensures data accuracy when handling high-value data and mission-critical tasks across large-scale businesses. -
Scale on demand
As your data storage needs grow, RS3617xs can be connected to a dedicated RX1217/RX1217RP2 expansion unit, allowing you to expand storage capacity up to 36 drives3 without disrupting service. The high-bandwidth expansion cable ensures speedy data transmission between the main server and expansion unit. Go to the RX1217/RX1217RP product page. -
10 GbE network capability
In addition to the default four Gigabit ports, RS3617xs comes with dual PCIe 3.0 x8 slots that supports up to two 10GbE Network Interface Cards (NIC), maximizing bandwidth and meeting high performance requirements for data-intensive applications. -
Reliable redundancy mechanisms
RS3617xs comes with comprehensive redundancy mechanisms to ensure business continuity. Built-in four LAN ports with failover provides the reliable redundancy in the event of unexpected network failure. The high reliability system design including fan-less CPU heat-sink and passive cooling technologies prevents single point of failure. -
Hardware encryption engine enhances file transfer speeds
RS3617xs is equipped with an encryption engine which offloads encryption calculation tasks away from the main CPU. Thus, the CPU can be free for other important tasks. In addition, Advanced Encryption Standard (AES) on shared folders with hardware acceleration ensures security without compromising access performance, providing over 2,612 MB/s in reading. -
SSD cache technology
RS3617xs enables the combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS3617xs offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant server performance enhancement.
- Synology RackStation RS3617xs - NAS server - 24 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 24 TB
- Max Supported Capacity
- 96 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 44.5 cm x 57 cm x 8.8 cm
- Processor
- 1 x Intel Xeon E3-1230V2 3.3 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 12 x 2 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 75
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- 5-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 24 TB
- 96 TB
- 44.5 cm
- 57 cm
- 8.8 cm
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 12 x 2 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- L2TP, iSCSI
- Remote Management Protocol
- SNMP, Telnet, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, LDAP support, wake on LAN (WOL), antivirus analysis, Access Control List (ACL) support, iTunes server, UPnP Media Server, surveillance station, DLNA Media Server, cloud backup, VPN Server
- Encryption Algorithm
- AES, SSL, TLS
- DLNA CERTIFIED
Security DVR
- 75
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 2 (free) x PCI Express 3.0 x8
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x InfiniBand
- Wake on LAN, built-in 4 cooling fans
- FCC Class A certified, RoHS, BSMI Class A
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- Power Provided
- 500 Watt
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 5 - 95%
