Synology RS3617XS+/72TB-REDPRO 12 Bay Rackmount NAS
Quicklinx: CFRCWS00 Mfr#: RS3617XS+/72TB-REDPRO
  • Xeon
Synology RackStation RS3617xs+ provides reliable, superior-performance network attached storage solution for large scale businesses with comprehensive business applications. With built-in 10GBase-T support and scalability of up to 36 drives, RS3617xs+ simplifies data management, optimizes virtualization environments, and rapidly expands storage capacity with minimal time investment in setup and maintenance.
  • Blazing performance
    RS3617xs+ comes with two 10GBase-T and four 1GbE RJ-45 ports by default, bringing flexible network configuration and bandwidth utilization. With the help of an advanced processor, RS3617xs+ delivers blazing performance.
  • Btrfs - next-generation storage efficiency
    RS3617xs+ integrates the Btrfs file system, bringing the advanced storage technologies to meet the management needs of modern large scale businesses:
  • Virtualization ready
    RS3617xs+ provides seamless storage solutions for virtualization environments. As the centralized storage of a virtual environment, RS3617xs+ enables virtual machine migration, allowing movement from server to server whilst eliminating service downtime and disruption to user.
  • Reliability, availability & disaster recovery
    System reliability is of paramount importance to businesses which depend upon their commercial servers every day. RS3617xs+ responds to these concerns with wide-ranging availability and redundancy features.
Synology RackStation RS3617xs+ - NAS server - 72 TB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
72 TB
12 (installed) / 12 (max)
69.2 cm x 43.05 cm x 8.8 cm
14.5 kg ()
1 x Intel Xeon D-1531 2.2 GHz (6-core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 6 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
IP Cameras Supported
90
RAM
8 GB
5-year warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
72 TB
69.2 cm
43.05 cm
8.8 cm
14.5 kg ()
Processor / Memory
Processors Installed
Number of Cores
6-core
Max Supported Qty
1
RAM
8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
12 x 6 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Buffer Size
128 MB
Network / Transport Protocol
L2TP, iSCSI
Remote Management Protocol
SNMP, Telnet, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), antivirus analysis, Access Control List (ACL) support, iTunes server, UPnP Media Server, surveillance station, DLNA Media Server, cloud backup, VPN Server
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED
Security DVR
90
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x InfiniBand , 2 x Ethernet 10Gb - RJ-45
Wake on LAN, built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Provided
500 Watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
