Designed for businesses seeking large data storage capacity, RS3617RPxs is a high-performance, 12-bay rackmount NAS equipped with redundant power supplies, ensuring business continuity. Organizations can integrate seamlessly with virtualization solutions.
High-performance NAS server
RS3617RPxs delivers stunning performance. Equipped with DDR4 ECC RAM, RS3617RPxs ensures data accuracy when handling high-value data and mission-critical tasks across large-scale businesses. -
Scale on demand
As your data storage needs grow, RS3617RPxs can be connected to one or two dedicated expansion units, allowing you to expand storage capacity without disrupting service. The high-bandwidth cable ensures speedy data transmission between the main server and expansion unit. -
10GbE network capability
In addition to the four built-in Gigabit ports, RS3617RPxs comes with two PCIe 3.0 x8 slots that allow for the installation of two 10GbE network interface cards, maximizing bandwidth and meeting high-performance requirements for data-intensive applications. -
Reliable redundancy mechanisms
RS3617RPxs comes with comprehensive redundancy mechanisms to ensure business continuity. Built-in four LAN ports with failover provide reliable redundancy in the event of unexpected network failure. The high reliability system design, including fanless CPU heat-sink and passive cooling technologies, prevents a single point of failure. Other features such as redundant power supplies, system fans, and network ports with failover support ensure continual service uptime. -
Enhanced encryption performance
RS3617RPxs is equipped with an encryption engine which offloads encryption calculation tasks from the main CPU, thus allowing it to perform other important tasks. In addition, Advanced Encryption Standard (AES) on shared folders with hardware acceleration ensures security without compromising access performance. -
SSD cache technology
RS3617RPxs enables the combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS3617RPxs offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant server performance enhancement.
- Synology RackStation RS3617RPxs - NAS server - 48 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 48 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 69.2 cm x 43.05 cm x 8.8 cm
- 14.5 kg ()
- Processor
- 1 x Intel Xeon D-1521 2.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 12 x 4 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 75
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- 5-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 48 TB
- 69.2 cm
- 43.05 cm
- 8.8 cm
- 14.5 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 12 x 4 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Data Link Protocol
- L2TP, iSCSI
- Remote Management Protocol
- SNMP, Telnet, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, LDAP support, wake on LAN (WOL), antivirus analysis, Access Control List (ACL) support, iTunes server, UPnP Media Server, surveillance station, DLNA Media Server, cloud backup, VPN Server
- Encryption Algorithm
- AES, SSL, TLS
- DLNA CERTIFIED
Security DVR
- 75
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 2 (free) x PCI Express 3.0 x8
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x InfiniBand
- Wake on LAN, built-in 4 cooling fans
- FCC Class A certified, RoHS, BSMI Class A
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 5 - 95%
