Product
Synology RS2416+ 48TB (12 x 4TB RED PRO) 12 Bay NAS Solution
Quicklinx: BRS0WS00 Mfr#: RS2416+/48TB-RED PRO
  • Atom
Designed for growing businesses, this powerful network-attached storage solution features schedulable snapshots and resilient data integrity, on-the-fly scalability, as well as reliable performance required by modern workplaces. When dealing with large-scale data storage, businesses require a solution that offers reliable backup and prevents file corruption. This NAS server ensures information is stored with a high level of data integrity, while providing flexible and efficient data protection tools. Snapshots preserve the history of a shared folder allowing you to save a significant amount of backup copies for point-in-time recovery. Snapshots can be automatically captured up to every 5 minutes, without noticeably impacting system performance. By generating checksums for files and metadata, the system can automatically detect and attempt to repair corrupted data or report errors to the administrator. With Btrfs, you can specify a storage limit for each shared folder, making it possible to precisely control space consumption.
  • Perfect data protection and integrity
  • Fast and efficient snapshots
  • Corruption detection and correction
  • Customizable quotas for shared folders
  • Powerful processor for speedy performance
    This NAS server is powered by the efficient processor running at 2.4 GHz. It delivers blazing-fast performance. This kind of power makes it easy for this server to run multiple applications and deliver consistently high throughput to all connected clients.
  • Redundancy mechanisms for higher uptime
    This NAS server includes redundant hardware mechanisms to ensure business continuity. The built-in Ethernet ports with link aggregation and failover provide reliability in the event of unexpected hardware failure, while the hot-swappable drives to minimize system downtime during drive replacement.
  • Protection by LUN backup, snapshot, and clone
    This NAS server enhances the ease of moving and copying data in a virtualized environment with the backup, snapshot, and clone.
  • All-in-one server
    With just one server it's possible to handle a vast amount of tasks. It helps your company to gain a competitive edge by acting as your multifunction server.
  • Secure your data
    It offers advanced security measures to protect you from potential security holes.
Synology RackStation RS2416+ - NAS server - 48 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
48 TB
Max Supported Capacity
96 TB
12 (installed) / 12 (max)
43 cm x 69.2 cm x 8.8 cm
12.56 kg
1 x Intel Atom C2358 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 4 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
48 TB
96 TB
43 cm
69.2 cm
8.8 cm
12.56 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
12 x 4 TB
Network / Transport Protocol
PPTP, L2TP, iSCSI, FTP, NFS
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
LDAP support, wake on LAN (WOL), Syslog support, antivirus analysis, video server, Access Control List (ACL) support, e-mail server, surveillance station, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
Security DVR
40
Compression Format
MJPEG, H.264
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x management
Built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Internal power supply
Installed Qty
1
Max Supported Qty
1
Power Provided
500 Watt
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
41.5 dBA
