Product
Synology RS18017xs+ 120TB (12x10TB WD GOLD) 12 Bay NAS Rack Unit
Quicklinx: CS70WS00 Mfr#: RS18017XS+/120TB-GOLD
  • Xeon
£7,760.14 ex VAT
£9,312.16 inc VAT
RS18017xs+ is built for flexible storage management with ultra-high performance at over 568,000 sequential read IOPS and 4,800 MB/s sequential read throughput. DDR4 ECC RDIMM and 10GbE connectivity guarantees data accuracy and performance for mission-critical environment.
  • Fully certified storage virtualization solutions
    Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface. VMware vSphere 6 and VAAI integration helps offload storage operations and optimizes computation efficiency. Windows Offloaded Data Transfer (ODX) speeds up data transfer and migration rate. OpenStack Cinder support turns your Synology NAS into a block-based storage component.
  • Comprehensive business solutions
    Seamlessly integrate the Synology NAS to your business environments with comprehensive productivity tools.
Synology RackStation RS18017XS+ - NAS server - 120 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
120 TB
12 (installed) / 12 (max)
48.2 cm x 72.4 cm x 8.8 cm
14.5 kg
1 x Intel Xeon D-1531 2.2 GHz (6-core)
Storage Controller
RAID SATA 6Gb/s / SAS - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 10 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
90
RAM
16 GB
Power Redundancy
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.10 or later
5 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
120 TB
48.2 cm
72.4 cm
8.8 cm
14.5 kg
Processor / Memory
Processors Installed
Number of Cores
6-core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
16 GB (installed) / 128 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s / SAS
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
12 x 10 TB
Network / Transport Protocol
PPTP, L2TP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), antivirus analysis, backup server, download client, file sharing, Access Control List (ACL) support, FTP server, e-mail server, surveillance station, DLNA Media Server, VPN Server
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
90
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
4 (total) / 1 (free) x DIMM 288-pin , 2 x PCI Express 3.0 x8
2 x USB 3.0 , 2 x Ethernet 10Gb - RJ-45 , 4 x Ethernet 1000Base-T - RJ-45 , 1 x serial RS-232 (management) - DB-9
Built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
141.96 Watt
Power Provided
500 Watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Brand: Synology
Price Range Ex VAT: 1500+
