- Synology RackStation RS1619xs+ - NAS server - 8 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 1U
- Total Storage Capacity
- 8 TB
- Max Supported Capacity
- 56 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 48 cm x 51.86 cm x 4.4 cm
- Processor
- 1 x Intel Xeon D-1527 2.2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, RAID F1
- Hard Drive
- 4 x 2 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 75
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 5-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 8 TB
- 56 TB
- 48 cm
- 51.86 cm
- 4.4 cm
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.7 GHz
- RAM
- (supported) 8 GB (installed) / 64 GB (supported) - DDR4
- ECC
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 4 x 2 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, PPTP, L2TP, iSCSI, FTP, NFS
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), IP address filtering, backup server, download client, anti-malware protection, event log, Access Control List (ACL) support, Samba support, FTP server, reset button, bandwidth control, surveillance station, PXE support, DLNA Media Server, cloud backup, VPN Server, Dropbox support, anti-virus protection, Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, hubiC support, OpenStack Swift-compatible, cloud station server, MailPlus server, Amazon S3 support
- Encryption Algorithm
- SSL, TLS, AES-NI
- DLNA CERTIFIED
Security DVR
- 75
- Compression Format
- MJPEG, H.264, H.265
- Image Resolution
- 1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin , 2 (total) / 2 (free) x M.2
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial (management) - DB-9
- Wake on LAN, built-in 2 cooling fans, scheduled power on/off
- VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM
- Included Accessories
- Accessory pack
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 68.68 Watt
- Power Provided
- 150 Watt
- Software Included
- McAfee AntiVirus (Trial)
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 39.3 dBA
