Synology RS1619xs+ 48TB (4 x 12TB ULTRA)4 Bay Rackmount NAS
Quicklinx: DZ3WWS00 Mfr#: RS1619xs+/48TB-ULTRA
  • Xeon
RS1619xs+ is a high-performance and scalable 1U rackmount NAS designed with upgradable memory and M.2 SSD cache configuration to meet the needs of modern businesses that require a flexible, reliable, and efficient storage solution.
Synology RackStation RS1619xs+ - NAS server - 48 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
48 TB
Max Supported Capacity
56 TB
4 (installed) / 4 (max)
48 cm x 51.86 cm x 4.4 cm
1 x Intel Xeon D-1527 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, RAID F1
Hard Drive
4 x 12 TB SATA 6Gb/s - Seagate
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
75
RAM
8 GB
Power Redundancy
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
48 TB
56 TB
48 cm
51.86 cm
4.4 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
8 GB (installed) / 64 GB (supported) - DDR4
ECC
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Hard Drive
HDD - hot-swap - 3.5"
4 x 12 TB
Interface Type
SATA 6Gb/s
Manufacturer
Seagate
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP, NFS
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), IP address filtering, backup server, download client, anti-malware protection, event log, Access Control List (ACL) support, Samba support, FTP server, reset button, bandwidth control, surveillance station, PXE support, DLNA Media Server, cloud backup, VPN Server, Dropbox support, anti-virus protection, Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, hubiC support, OpenStack Swift-compatible, cloud station server, MailPlus server, Amazon S3 support
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
75
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin , 2 (total) / 2 (free) x M.2
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial (management) - DB-9
Wake on LAN, built-in 2 cooling fans, scheduled power on/off
VCCI, BSMI, CCC, FCC, RoHS, KC, EAC, RCM
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
68.68 Watt
Power Provided
150 Watt
Software Included
McAfee AntiVirus (Trial)
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
39.3 dBA
