Synology RS1221RP+ 8 Bay Rack Enclosure
Quicklinx: G4RFWS00 Mfr#: RS1221(RP)+
Interface: Fast Ethernet, Ethernet, Gigabit Ethernet
Type: 8-Bay
Capacity: 0GB
£1,139.47 ex VAT
£1,367.36 inc VAT
RS1221RP+, at only 30 to 38 centimeters deep, is built for space-sensitive deployments. Boasting over 100K 4K random read IOPS and 2,315 MB/s sequential read, RS1221RP+ is equipped to handle heavy workloads in data-intensive environments. RS1221RP+ additionally features an extra level of protection with redundant power supplies.
Key Product Info
Redundant powerMaximize service availabilityData integrity and protection
Product Features
Redundant power-
Reduce the chance that power disruptions on a single distribution channel or PDU causes data and service availability degradation.Maximize service availability When paired with another identical unit, Synology High Availability enables automatic minute-level failover between two clustered servers in the event of a server failure to minimize service downtime.Data integrity and protection ECC memory and the Btrfs file system bring higher reliability and snapshot capabilities to help prevent data corruption and simplify data protection.
  • Redundant power
  • Maximize service availability
  • Data integrity and protection
Synology RackStation RS1221RP+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
108 TB
0 (installed) / 8 (max)
48.2 cm x 40.75 cm x 8.8 cm
11.7 kg ()
1 x Ryzen Embedded V1500B 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
4 GB
Power Redundancy
Microsoft Windows 7 or later, Apple macOS 10.12 or later
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
108 TB
48.2 cm
40.75 cm
8.8 cm
11.7 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR4
ECC
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Network / Transport Protocol
PPTP, L2TP, iSCSI, FTP, SMB, NFS, HTTP, HTTPs, SMB v2, Telnet, SMB v3
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), Server Message Block 2.0 (SMB 2.0), Server Message Block 3.0 (SMB 3.0), Network File System v3 (NFS v3), Network File System v4 (NFS v4), Network File System v4.1 (NFS v4.1)
Firewall protection, LDAP support, WOL, Syslog support, antivirus analysis, High Availability, video server, POP3 e-mail server, ACL support, RADIUS support, FTP server, e-mail server, reset button, surveillance station, DNS server, VPN Server, Link Aggregation, scheduler, failover protection, Btrfs, NV, file station, EXT4 file system, SSD trim, RAID migration, MailPlus server, hybrid backup sync
Encryption Algorithm
AES, SSL, TLS
Security DVR
40
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x expansion slot
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.2 Gen 1 , 1 x eSATA
Built-in 2 cooling fans, 80mm cooling fan
VCCI, BSMI, CCC, FCC, AES, RoHS, KC, EAC, RCM
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
61.94 Watt
Power Provided
350 Watt
5 °C
35 °C
5 - 95%
Sound Emission
40 dBA
Hard Drives
G4RF Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £442.11
Type: 8-Bay
Interface: Ethernet
Interface: Gigabit Ethernet
Capacity: 0GB
Brand: Synology
Price Range Ex VAT: £1000 - £1500
