Synology RS1219+/48TB-EXOS 8 Bay Rackmount NAS
Quicklinx: DRWFWS00 Mfr#: RS1219+/48TB-EXOS
  • Atom
Marketing description is not available.
  • A scalable storage server that grows with your business
    Synology's RS1219+ is an 8-bay 2U NAS server that provides storage scalability and is ideal for small and medium-sized businesses. Further increase storage performance with an optional M.2 SSD cache, or increase network speeds with the addition of a 10 GbE NIC. The RS1219+ will work great as a backup destination to protect your most important assets or as a centralized file server to share files across platforms.
  • Meet the compact rack server for deployments
    The RS1219+ can support up to 12 drives while using a single Synology RX418 expansion unit simultaneously. As both the RS1219+ and RX418 are only 12 inches deep, they can be successfully placed in a 2-post rack or wall-mounted rack.
  • The perfect solution for file management and sharing
    File Station is a web-based, fast and secure management tool that enables easy drag-and-drop operation without complex configuration on Macs and PCs. Advanced search and filtering tools make it easy to organize and share files. To ensure full compatibility, the RS1219+ supports the following protocols: AFP, FTP, iSCSI, NFS, SMB and WebDAV.
  • Generation file system oriented towards better data protection
    The Btrfs file system provides advanced memory technologies and optimized snapshots to prevent data corruption and reduce maintenance burden. It ensures high-level data integrity, and uses flexible and effective tools for data protection and recovery.
  • Real-time collaboration in the private cloud
    Office is a suite of collaboration tools that combines the convenience and usability of public clouds with the protection of private cloud-level data. It allows you to work seamlessly on documents and spreadsheets in a protected environment.
  • Fully certified storage virtualization solutions
    Synology's iSCSI storage fully supports most virtualization solutions, boosting productivity with an easy-to-use management interface. The integration of VMware vSphere 6 and VAAI helps reduce operation load and optimize computing performance. Windows Offloaded Data Transfer (ODX) technology increases transfer speed and migration speed. OpenStack Cinder support allows you to turn your Synology NAS into a block-based storage component.
Synology RackStation RS1219+ - NAS server - 48 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
48 TB
Max Supported Capacity
108 TB
8 (installed) / 8 (max)
48.19 cm x 30.66 cm x 8.8 cm
6.9 kg ()
1 x Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 6 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
48 TB
108 TB
48.19 cm
30.66 cm
8.8 cm
6.9 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 16 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
8 x 6 TB
Network / Transport Protocol
PPTP, L2TP, iSCSI, FTP, NFS
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
LDAP support, wake on LAN (WOL), Syslog support, antivirus analysis, video server, Access Control List (ACL) support, e-mail server, surveillance station, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
Security DVR
40
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 2.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA
Built-in 2 cooling fans
RoHS
Accessory pack
Internal power supply
Installed Qty
1
Max Supported Qty
1
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
