Synology HAT5300-8T 8TB 3.5" SATA HDD
Quicklinx: G598WS00 Mfr#: HAT5300-8T
Form Factor: 3.5"
Type: Hard drive
Capacity: 8TB
Spin Speed (rpm): 7200rpm
Hurry, only 3 left in stock!
£196.10 ex VAT
£235.32 inc VAT
Synology HAT5300 HDD offers class-leading performance thanks to tight integration with DSM and Synology hardware. With over 300,000 hours of in-house validation testing and backed by Synology’s 5-year limited warranty, the HAT5300 series brings unmatched reliability to Synology deployments.
  • Scale up confidently
    Synology HAT5300 drives are engineered to provide fast and dependable performance, even for a large number of clients. Firmware and software collaborate to ensure maximum performance, delivering high sequential read performance. HAT5300 provides outstanding performance for large-scale video surveillance, multimedia post-production and enterprise file server environments.
  • Maximum endurance and reliability
    Combined with data protection solutions running on Synology systems, you can confidently depend on your data 24/7 using HAT5300 series drives.
  • Simplified maintenance
    DSM updates will ensure that compatible Synology drives will be updated together with the operating system. This reduces the number of maintenance sessions IT teams need to schedule while also increasing the entire system's service availability. Simplify IT infrastructure planning requirements by getting support for the entire system from Synology.
Synology HAT5300 - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Workload up to 550 TB per year
101.85 mm x 147 mm x 26.1 mm
770 g
5-year warranty
Synology RS820RP+, SA3400, SA3600; Deep Learning NVR DVA3219, DVA3221; Disk Station DS1520+, DS1618+, DS1621+, DS1621XS+, DS1819+, DS1821+, DS220+, DS2419+, DS3018xs, DS3617xs, DS420+, DS720+, DS920+; RackStation RS1221+, RS1221RP+, RS1619xs+, RS18017XS+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS3621RPxs, RS3621xs+, RS4017XS+, RS4021xs+, RS820+, RS820RP+
8 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
770 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
230 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Expansion & Connectivity
Compatible Bay
3.5"
Power Consumption
6.38 Watt (idle) , 9.1 Watt (random read/write)
CSA, UL, TUV, BSMI, RoHS, ICES, KC, EAC, RCM
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 90% (non-condensing)
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (operating)
0.75 g @ 5-300 Hz
Vibration Tolerance (non-operating)
3 g @ 5-500 Hz
Synology RS820RP+, SA3400, SA3600 , Synology Deep Learning NVR DVA3219, DVA3221 , Synology Disk Station DS1520+, DS1618+, DS1621+, DS1621XS+, DS1819+, DS1821+, DS220+, DS2419+, DS3018xs, DS3617xs, DS420+, DS720+, DS920+ , Synology RackStation RS1221+, RS1221RP+, RS1619xs+, RS18017XS+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS3621RPxs, RS3621xs+, RS4017XS+, RS4021xs+, RS820+, RS820RP+
Form Factor: 3.5"
Type: Hard drive
Capacity: 8TB
Brand: Synology
Stock Status: In stock
