Synology DX517 5 Bay NAS Desktop Enclosure
Quicklinx: D88BWS00 Mfr#: DX517
Capacity: 0GB
£382.54 ex VAT
£459.04 inc VAT
Easily add 5 additional drive bays to Synology DiskStation. Supporting both 2.5" and 3.5" SATA drives, DX517 is a flexible solution supporting on-the-fly volume expansion or serving as a local backup destination.
  • 5-bay 3.5"/2.5" SATA expansion
  • Online volume expansion
    Managed from DiskStation Manager on the host NAS, the additional bays in the DX517 are immediately ready to be used once connected. On-the-fly volume expansion ensures that storage and services on the host are not interrupted during volume expansion.
  • Hot-swappable drive tray design
    The hot-swappable drive trays of DX517 allow easy drive installation and replacement without powering down the system. Screwless drive tray design reduces the time needed for system setup.
  • Dedicated local backup solution
    Synology DX517 can be used as a dedicated local backup solution for the Synology DiskStation. When created as a separate volume, the DX517 provides a great backup solution to its local hard disks in case of system failure.
Synology DX517 - storage enclosure
Storage enclosure
0 (installed) / 5 (max)
Hard Drive
No HDD - hot-swap
AC 120/230 V - 50 - 60 Hz
24.8 cm x 23.3 cm x 15.7 cm
3.91 kg
3-year warranty
Storage enclosure
Chassis
0
Supported Devices / Modules Qty
5
Hard Drive
No HDD - hot-swap
Expansion Bays
5 (total) / 5 (free) x hot-swap - 2.5" / 3.5" shared
Built-in 2 cooling fans
1 x eSATA cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
29.9 Watt
Power Provided
200 Watt
24.8 cm
23.3 cm
15.7 cm
3.91 kg
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
30 dBA
Capacity: 0GB
Brand: Synology
Price Range Ex VAT: 300 - 500
