Product
Brand
Synology DX513 30TB-Red  5 Bay NAS
Quicklinx: B0HTWS00 Mfr#: DX513/30TB-RED
Synology DX513 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStation models. The DX513 seamlessly scales up the storage capacity of the DiskStation by additional 5 hard drives on-the-fly when connected directly to an expansion cable.
Synology DX513 - storage enclosure
Storage enclosure
5 (installed) / 5 (max)
Hard Drive
5 x 6 TB HDD - hot-swap
AC 120/230 V - 50 - 60 Hz
24.8 cm x 23.3 cm x 15.7 cm
3.91 kg
3 years warranty
Storage enclosure
Chassis
5
Supported Devices / Modules Qty
5
Hard Drive
HDD - hot-swap
5 x 6 TB
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
Built-in 2 cooling fans
1 x data cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
45.1 Watt
24.8 cm
23.3 cm
15.7 cm
3.91 kg
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
30 dBA
