Synology DX1215 12 Bay Desktop Expansion Unit
Quicklinx: B0HLWS00 Mfr#: DX1215
Type: 12-Bay
Interface: Gigabit Ethernet
Capacity: [N/A]
Hurry, only 1 left in stock!
£750.05 ex VAT
£900.06 inc VAT
Synology DX1215 delivers an effortless volume expansion and data backup solution for selected Synology DiskStation servers by providing an additional 12 drive slots with SATA III 6Gb/s interface support.
  • Volume expansion & backup
    When drive capacity is running low on a Synology DiskStation, Synology DX1215 provides an easy way to immediately scale capacity by providing an additional 12 drive slots. A RAID volume on the Synology DiskStation can be expanded directly without having to reformat the existing drives, ensuring the Synology DiskStation continues providing services during capacity expansion. Synology DX1215 can serve as a dedicated local backup solution for a Synology DiskStation. When created as a separate volume, the Synology DX1215 provides a great backup solution for local drives in case of system failure.
  • Reliable Plug-and-Use design
    DX1215 securely connects to Synology's DiskStation servers with a specially designed expansion cable, ensuring easy connection and maximum data throughput. The 6Gb/s connection speed allows the drives in the connected Synology DX1215 to operate as the internal ones of Synology DiskStation.
  • Green & easy to manage
    Hibernation mode can be manually configured to start automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of hard drives. DX1215 will also smartly power on/off with the attached DiskStation, so no user intervention is needed to keep this system running smartly and efficiently.
Synology DX1215 - hard drive array
Hard drive array
Max Supported Capacity
72 TB
InfiniBand
12 (installed) / 12 (max)
Supported Drives
SATA-600
Storage Controller
(SATA 6Gb/s)
Hard Drive
0 - hot-swap
AC 120/230 V - 50/60 Hz
27 cm x 30 cm x 34 cm
9.02 kg
5-year warranty
Hard drive array
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
Storage
72 TB
HDD Array External Interface
InfiniBand
Storage Controller
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hard Drive
Hot-swap
0
Expansion Bays
12 (total) / 12 (free) x hot-swap - 3.5"
1 x InfiniBand
1 x InfiniBand cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
Power Provided
500 Watt
27 cm
30 cm
34 cm
9.02 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
27.2 dBA
Type: 12-Bay
Capacity: [N/A]
Brand: Synology
Price Range Ex VAT: £750 - £1000
Stock Status: In stock
