DS716+II is the perfect combination of scalability, performance, and versatility. It can deliver high-speed encrypted data transfer, 4K transcoding, and is running Btrfs, an enhanced file system.
- Synology Disk Station DS716+II - NAS server - 4 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 4 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10.35 cm x 23.2 cm x 15.7 cm
- Processor
- 1 x Intel Celeron N3160 1.6 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s / eSATA - RAID 0, 1, JBOD
- Hard Drive
- 2 x 2 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- 3 years warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 4 TB
- 10.35 cm
- 23.2 cm
- 15.7 cm
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / eSATA
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 2 TB
- Data Link Protocol
- PPTP, iSCSI, SMTP, FTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, IPP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, LDAP support, wake on LAN (WOL), print server, antivirus analysis, web server, backup server, download client, event log, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, FTP server, e-mail server, UPnP Media Server, reset button, bandwidth control, surveillance station, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, 4K resolution support, cloud backup, VPN Server, Wi-Fi USB dongle support
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- DLNA CERTIFIED, UPnP
Security DVR
- Compression Format
- MJPEG, MPEG-2, H.264
- Image Resolution
- 1920x1080, 2048x1536, 1280x800, 2591x1944, 4096x2160
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 3 x USB 3.0 , 2 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA
- Cables Included
- 2 x network cable
- Built-in cooling fan, AirPrint, Google Cloud Print
- RoHS
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 5 - 95%
- Sound Emission
- 18 dBA
