Your basket is empty
Synology DS716+II 2TB (2 x 1TB WD RED) 2 Bay Desktop NAS
Quicklinx: C51HWS00 Mfr#: DS716+II/2TB-RED
  • Celeron
DS716+II is the perfect combination of scalability, performance, and versatility. It can deliver high-speed encrypted data transfer, 4K transcoding, and is running Btrfs, an enhanced file system.
Synology Disk Station DS716+II - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
2 (installed) / 2 (max)
10.35 cm x 23.2 cm x 15.7 cm
1 x Intel Celeron N3160 1.6 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA - RAID 0, 1, JBOD
Hard Drive
2 x 1 TB
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
10.35 cm
23.2 cm
15.7 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 1 TB
Network / Transport Protocol
PPTP, iSCSI, SMTP, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), print server, antivirus analysis, web server, backup server, download client, event log, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, FTP server, e-mail server, UPnP Media Server, reset button, bandwidth control, surveillance station, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, 4K resolution support, cloud backup, VPN Server, Wi-Fi USB dongle support
Encryption Algorithm
SSL, TLS, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
Compression Format
MJPEG, MPEG-2, H.264
Image Resolution
1920x1080, 2048x1536, 1280x800, 2591x1944, 4096x2160
Expansion Bays
2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
3 x USB 3.0 , 2 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA
2 x network cable
Built-in cooling fan, AirPrint, Google Cloud Print
RoHS
External power adapter
Power Provided
65 Watt
Limited warranty - 3 years
5 °C
5 - 95%
Sound Emission
18 dBA
