Synology DS418 4 Bay Diskless NAS
Quicklinx: D47JWS00 Mfr#: DS418
Capacity: 0GB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
Type: 4-Bay
Hurry, only 1 left in stock!
£328.60 ex VAT
£394.32 inc VAT
Synology DiskStation DS416 is a high-performance and feature-rich 4-bay NAS specifically designed for small businesses and home users to effectively manage, protect and share data. Equipped with comprehensive office applications, DS416 raises working efficiency while securing data with full backup solutions.
  • Surveillance station
    Complete surveillance solution for recording, monitoring, and management.
  • Desktop backup
    Simplified backup solution for your Mac, PC, and mobile devices.
  • Public cloud integration
    Backup and synchronize data easily between your public cloud accounts and your NAS.
  • SHR technology
    Storage management is easy with SHR technology. SHR is an automated RAID management system allowing you to easily create and expand storage volumes and migrate RAID types without requiring details on RAID.
Synology Disk Station DS418 - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
40 TB
0 (installed) / 4 (max)
19.9 cm x 22.3 cm x 16.6 cm
2.28 kg
1 x RTD1296 1.4 GHz (Quad-Core)
Storage Controller
RAID RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
30
Performance
Throughput (reading): 226 MB/s , Throughput (writing): 170 MB/s
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later, Microsoft Windows 7 / 10
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
40 TB
19.9 cm
22.3 cm
16.6 cm
2.28 kg
Processor / Memory
Processors Installed
1 x RTD1296 1.4 GHz
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB DDR4
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
PPTP, L2TP, IPSec, SMTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Performance
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, reset button, bandwidth control, surveillance station, Energy Efficient Ethernet, WebDAV server, 4K resolution support, cloud backup, VPN Server, security lock slot (cable lock sold separately), 2 fans, Dropbox support, automated backup scheduling, Wi-Fi USB dongle support, Link Aggregation, Google Drive support, failover protection, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, OpenStack compatible, Full HD (1920 x 1080) streaming video support, file station, hubiC support, OpenStack Swift-compatible, WebDAV server support, Baidu cloud support
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
30
Compression Format
MPEG-4, MPEG-2, H.265, HEVC, VC-1
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160, 4096x2160
Automatic backup
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, hardware encryption, 24x7 continuous operation, scheduled power on/off
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
2 x hard drive security key, screws
External power adapter
26.49 Watt
Power Provided
90 Watt
Software Included
Drivers & Utilities
5 °C
5 - 95%
Sound Emission
20.9 dBA
Capacity: 0GB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Type: 4-Bay
Brand: Synology
Price Range Ex VAT: 300 - 500
