Your basket is empty
Synology DS416Play/4TB-RED 4 Bay NAS
Quicklinx: C8C1WS00 Mfr#: DS416PLAY/4TB-RED
Capacity: 4TB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Celeron
16 in stock
£574.59 ex VAT
£689.50 inc VAT
Synology DiskStation DS416play is a 4-bay NAS server with incredible fun. The massive storage capacity allows you to store your entire multimedia library and turns it into a centralized multimedia center. Powered by a hardware transcoding engine, DS416play delivers real-time transcoding of 4K Ultra HD to various kinds of devices you have, giving you a smooth and high quality streaming experience.
Synology Disk Station DS416Play - NAS server - 4 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
4 TB
4 (installed) / 4 (max)
20.3 cm x 23.32 cm x 16.5 cm
2.04 kg
1 x Intel Celeron N3060 1.6 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 1 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
25
RAM
1 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
4 TB
20.3 cm
23.32 cm
16.5 cm
2.04 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM Installed
1 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
4 x 1 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, SMTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, reset button, bandwidth control, surveillance station, Energy Efficient Ethernet, VPN Server, automated backup scheduling, Wi-Fi USB dongle support
DLNA CERTIFIED, UPnP
Security DVR
25
Compression Format
MPEG-2
Frame Rate
30 fps (playback)
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
3 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation
AES
External power adapter
Software Included
Drivers & Utilities
Limited warranty - 3 years
5 °C
5 - 95%
Synology DS416Play/4TB-RED 4 Bay NAS Bundle deal on Synology DS416Play/4TB-RED 4 Bay NAS
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.43 | in stock
£577.31
saving £2.72
Capacity: 4TB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: Synology
Price Range Ex VAT: 500 - 750
